Activity › Forums › Panasonic Cameras › Movement On Stills Tutorial
  • Movement On Stills Tutorial
    Posted by Dan Sheridan on May 24, 2006 at 4:36 pm
    Not sure if anyone has mentioned this already, but I found the tutorial really hard to watch as it appeared the software used to make the tutorial was tracking the mouse movement on screen.
    Good tutorial – any chance next time of having just a fixed screen?
    Cheers,
    Dan 😉
    Dan Sheridan
    Video Monkeys LLP
    DVD & CD Video Production Services
    https://www.videomonkeys.com
    Shane Ross replied 20 years, 4 months ago 2 Members · 1 Reply
  • Shane Ross
    May 24, 2006 at 7:52 pm
    I could do that. The only issue I have is that then the images and wording might be too small to read. But I can understand that the screen movement the way it is can cause seasickness.
    I will look into that. I might make it big enough that I can cut closer when I need to.
    Thank you,
    Shane
    Alokut Productions
    http://www.lfhd.net
