Activity Forums Adobe After Effects movement of layer between key frames of the same value?
  • movement of layer between key frames of the same value?
    Posted by Chris Fairall on September 11, 2008 at 8:59 am
    Hi all, I am relatively new to After effects, I am animating pictures and text. My problem is that
    I have two key frames of the same value with a 1 minute gap in between but the layer just can’t help it’s self and just has to move along the z axis forward and then back to it’s original place?!
    There are no other keyframes in between or after it; I am confused. I have a camera flying around but is stationery for this time and is not interfering as no other layer is moving. If I add key frames to the other layers in the same way they all move forward and then back?
    can anyone help please,
    Chris Fairall replied 17 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
