Activity Forums Apple Final Cut Pro Legacy Movement doesn’t flow when animation is moved from After effects to Final cut
  • Movement doesn’t flow when animation is moved from After effects to Final cut
    Posted by Marina Vasconcelos on August 13, 2015 at 12:29 pm
    Hello everyone,
    I often put After Effects (13.5.0.347) animations on Final Cut so I can edit it (add pauses and sound effects). But lately the movements in the animations, like when something spins or when we zoom, look a bit laggy, it doesn’t flow as much as the after effects export.
    We’ve always done this so I am not sure why this is happening, we haven’t changed any settings. Does anyone have any idea why this would happen?
    This is how I’ve been told they are exporting from After Effects (if it matters at all):
    render quality best
    resolution full
    size 1920 by 1080
    25 frames a second
    Quicktime
    Video codec animation quality 100
    Let me know if there is any more information needed. I would definitely appreciate any help.
    Thank you!
    Marina Vasconcelos replied 11 years ago 1 Member · 1 Reply
  • Marina Vasconcelos
    August 13, 2015 at 5:02 pm
    haha, yes we do work together!
    Thank you, will try this and see if it solves it.
