Activity Forums Apple Final Cut Pro Legacy Movement doesn’t flow when animation is moved from After effects to Final cut
  • Movement doesn’t flow when animation is moved from After effects to Final cut
    Posted by Olly Lawer on August 13, 2015 at 1:36 pm
    Hi guys,
    So, we usually put animations made in After Effects into Final cut to edit (add pauses and sound effects etc). And it is usually fine, but lately once the animation is in Final cut it looks very laggy and like it is bad quality when compared to the .mov file we get out of After Effects. It looks especially bad during moves and zooms.
    Does anyone have any idea what could be happening?
    Any help will be appreciated.
    Thank you!
    Olly Lawer
    Olly Lawer replied 11 years ago 2 Members · 2 Replies
  • Nick Meyers
    August 13, 2015 at 11:34 pm
    yes, what is the format of the media from AE?
    if your animations are using “Animation” codec, then they will play back the way you describe.
    it’s data rate is very big.
    nick
  • Olly Lawer
    August 18, 2015 at 4:07 pm
    We solved it by exporting it at a higher frame rate from AE (50 instead of 25). We never had this problem before but this solved it so it’s all good! Thank you!
    Olly Lawer
