Activity Forums Maxon Cinema 4D movement between 2 identical keyframes
  • movement between 2 identical keyframes
    Posted by Nate Tull on December 18, 2007 at 12:04 am
    I have a 3dtext word that comes on from left and then sits in the center of screen for 20 frames then exits to the right. i set a keyframe at 0 @ 10 i set a keyframe where my logo lands then is suppose to sit for 20 frames so i set a keyframe that exactly like the keyfame i set @ 10 but my logo drifts back and forth between those 2 keyframes why is that and how can i get it to just sit there?
    Nate Tull replied 18 years, 9 months ago 2 Members · 2 Replies
  • Brian Jones
    December 18, 2007 at 1:42 am
    check out the F-Curves. Keyframes by default are strung together with soft splines but the ‘nodes’ (keyframes) can have soft/linear/custom tangents on either side and they don’t need to be the same on both sides. So you want a linear (flat) line between the keyframes where the object is supposed to stay still and the splines coming in and going out can be anything that you think looks right.
  • Nate Tull
    December 18, 2007 at 12:16 pm
    thank you sooo much im very new to C4D you help alot.
