Activity › Forums › DaVinci Resolve › Move v9 power grades to v10
  • Andrew Smith
    November 19, 2013 at 1:55 pm
    Yeah just make a new project in v9 copy the power grades in gallery to regular still store and then save project. Then open 10 and import that project, the names should have stayed and in gallery page you should he able to move those into power grades retaining the names.
  • Paul Provost
    November 20, 2013 at 12:01 am
    doh! guess I should have posted this in basics.
    http://www.4Kfinish.com | owner-colorist | Hollywood, CA
    http://www.facebook.com/4kFinish
    Twitter 4kfinish
  • Marc Wielage
    November 20, 2013 at 12:21 am
    I was gonna suggest exporting a DPX still of the Powergrade correction, then import the DPX still (and associated correction) together to the still page and then to the Powergrade section. But open the old session should work, too.
  • Paul Provost
    November 20, 2013 at 12:24 am
    that looses the name.
    I just didn’t think you could move PG to stills folder in v9.
    Andrew’s procedure is the only way to move an entire PowerGrade library.
    Twitter 4kfinish
  • Marc Wielage
    November 20, 2013 at 12:41 am
    True, the entire stills procedure within Resolve is screwy because it’s based on timeline number and scene (if memory serves). I wish they could save stills based on the user-added name. This wreaks havoc when you have multiple timelines and needed to export lots of stills from the same session, all of which technically have the same “Still Name” (like 1.3.11 or something like that).
    But you can grab a DPX still of a powergrade and then use that still and the associated DRX correction file, then just rename it. You only have to do it once, assuming you don’t have hundreds of powergrades.
    Blackmagic should probably re-examine the methodology behind importing stills, corrections, and powergrades and have a mode that will automatically retain the names and put them in the right place. This is doable — it’s more a question of what they prioritize for features and fixes.
  • Paul Provost
    November 20, 2013 at 2:00 am
    not hundreds, but dozens….
    I’d rather have them their spend time adding 3rd party control panel mapping!
    Twitter 4kfinish
