Activity › Forums › Adobe After Effects Expressions › move to layer position
Posted by Madli Man on March 27, 2013 at 1:38 pmHi all,
I dont know if this question been posted. but i did search for an expression that can move 3d layer to another 3d layer position (without keyframe) by index.
let say: layer1 move to layer2. and next layer1 move to layer3. and next to layer4…
what i tried to do is similar with sure target from videocopilot.it that possible?
Ben Robinson replied 12 years, 6 months ago 3 Members · 5 Replies -
Dan Ebberts
March 27, 2013 at 2:25 pmYes, you could do that, but what controls the timing (how does the expression know when it’s time to move to the next layer)?
Dan
Madli Man
March 27, 2013 at 5:42 pmOh hi again Mr Dan. im glad hear that you said that posible to do. timing can be control via slider or variable. let say, 5 sec and move on. if you could write some, i most appreciate it.
Thanks Dan for replying.
Mad
Dan Ebberts
March 28, 2013 at 4:10 amPlay around with this. It should move layer 1 around the comp in 5-second increments. First to layer 2, then to layer 3, etc.
holdDur = 4;
moveDur = 1;
startIdx = 2; // start with layer 2segDur = holdDur + moveDur;
curSeg = Math.floor((time-inPoint)/segDur);
t = (time-inPoint) % segDur;
if (curSeg == 0){
L1 = null;
L2 = thisComp.layer(Math.min(thisComp.numLayers,curSeg+startIdx));
}else{
L1 = thisComp.layer(Math.min(thisComp.numLayers,curSeg+startIdx-1));
L2 = thisComp.layer(Math.min(thisComp.numLayers,L1.index+1));
if (t > moveDur){
L2.transform.position;
}else{
t1 = curSeg*segDur;
t2 = t1 + moveDur;
if (L1 == null)
p1 = value
else
p1 = L1.transform.position.valueAtTime(t1);
p2 = L2.transform.position,valueAtTime(t2);
ease(time,t1,t2,p1,p2)
Dan
Madli Man
March 28, 2013 at 2:51 pmOmg. Im speechless. this code work just like what im imagine. thank you Mr Dan. i will work around with this code.
again, THANK YOU MR DAN!!!!
Ben Robinson
February 28, 2014 at 1:17 amHi Dan,
I realise this thread is nearly a year old now–but I think it relates to what I’m looking for. I’m looking to do the same thing as the OP: move one layer’s position to another layer’s (possibly in another comp) position, according to its index; but I’d like to able to control / trigger it with keyframes (a slider on a null, perhaps) rather than have it automated. Additionally, I’d like to be able to apply this to several layers, but–let’s say they’re all controlled by a slider on a null layer (i.e., one controller for several layers)–offset the timing they each start animating.
Hope that makes sense.
Thank you in advance.
Ben
