Activity Forums Adobe Premiere Pro Move submix keyframes in CS5.5 or CS6
  • Move submix keyframes in CS5.5 or CS6
    Posted by Andy Milne on June 28, 2012 at 9:34 pm
    I have a 25min program that I mixed the audio on in CS5.5 W764 and used submixes for FX’s and music. I needed to add an ID board at the front so highlighted and moved all the video and audio tracks down by the 15sec I needed but I couldn’t move the keyframes for the submix track. In the ned I inserted the original sequence in another sequence and was able to shift the whole thing.
    I tried the keyframe shift in a trial of CS6 I have but still couldn’t shift the keyframes.
    Is there a way to shift submix keyframes?
    Cheers
    Andy
    Andy Milne replied 14 years, 2 months ago 1 Member · 1 Reply
  • Andy Milne
    June 29, 2012 at 3:56 am
    Ok, think I found my own answer. Use the pen tool to highlight all the keyframes you want then drag the keyframes to a new position. For more accurate positioning put your time cursor over the first key frame then pen select all the keyframes then CTRL+X to cut the frames. Move your time cursor to the new position of the first keyframe then CTRL+V to paste into the new position.
    Cheers
    Andy
