Activity Forums Adobe After Effects Move shape path position to 0,0, then shift all points on path back
  • Move shape path position to 0,0, then shift all points on path back
    Posted by Mike Foran on April 15, 2022 at 10:17 pm
    So I am importing a bunch of paths from Illustrator, and I want to
    employ the Trace Path script to attach a nulls to the paths. However,
    all the paths are coming in with unique path positions, and the Trace
    Path expression assumes each path is at 0,0 (This is for the path
    transform, not the layer transform). I am looking for a script that will
    shift a shape path to 0,0 and then alter the path itself so that all
    the points are back at their original location.
    Mike Foran replied 4 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
