Activity Forums Adobe After Effects Expressions Move Rig to parent comp
  • Move Rig to parent comp
    Posted by Steve Sierra on April 17, 2017 at 10:24 am
    I am working on a face rig.
    I have created an eye with it’s rig in “Eye Comp” (simplified shape layers controlling a null with all the sliders controlling all the properties in artwork shape layers).
    I want to move the rig to the face comp, and therefore have to change all the expressions to have the properties controlled by the new rig.
    I first tried the autoFixExpressions in a script… but since I didn’t create the expressions in a script, it doesn’t work. (or I’m doing it wrong…).
    I then wanted to “trick” the expression reader by using a text layer to define the rig’s comp… no result (or I’m doing it wrong again).
    Is there a way to do this or do I have to either change all the expressions manually or write a script that creates all the expressions to then be able to modify them at will ?
    Thanks in advance for any help ????
    Cheers !
    Steve Sierra replied 9 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 17, 2017 at 7:22 pm
    Your second method should work with something like this:
    rigCompName = thisComp.layer(“Eye Rig Comp Name”).text.sourceText.value;
    comp(rigCompName).layer(“Eye Control”).effect(“Slider Control”)(“Slider”)
    I’m not sure if the expressions will survive the editing of the text layer though.
    Dan
  • Steve Sierra
    April 18, 2017 at 4:42 am
    Thanks again Dan,
    I think I had forgotten the “.value” at the end of the source text… I’ll check it out as soon as I can.
    Cheers
