Activity › Forums › Adobe Premiere Pro › Move Playhead in Sequence like FCP?
Posted by Hirum Horkweller on June 5, 2015 at 5:03 amHey guys,
Wondering if anyone knows a way to move the Playhead Position in Premiere the same way you do in FCP, the way you can type + or – and any number to advance the playhead. When I type in a timecode manually in premiere this way it shows me typing it in the timecode, but when I press return nothing happens.
Any ideas?
– H
Hirum Horkweller replied 11 years, 3 months ago 6 Members · 15 Replies -
Trent Happel
June 5, 2015 at 5:41 amAre you displaying audio time units? Make sure you are set to video timecode or frames, then typing in timecode or + or – values in the timecode display (bottom left of Program or Source monitors) should move the playhead.
Trent Happel
Adobe
Premiere Pro -
Hirum Horkweller
June 5, 2015 at 5:51 amHey Trent,
Thanks for responding. I’m displaying video timecode (not exactly sure how to display audio only timecode in the sequence).
The strange thing is that if I click on the timecode and type in +10 and press return, the playhead will advance 10 frames. But if I just type +10 and press enter (without clicking in timecode first) it doesn’t work (though it does display “+10” in the timecode while I’m typing).
Is this a glitch or am I missing something? Here are screenshots to show what I’m talking about:
– H
Hirum Horkweller
June 5, 2015 at 5:54 amVersion of Premiere is 2014.0.1. The more I think about it, I think this must be a glitch.
One more thing worth mentioning: Every time I pressed Enter after entering the timecode it would start playing my timeline from the beginning. I realized that the Enter key is a default shortcut to render and play the sequence. So I disabled it in the shortcuts.
Basically I just want to be able to quickly type + or – and the number of frames I want to move the playhead, like in FCP, without having to use the mouse.
Trent Happel
June 5, 2015 at 5:58 amHmmm, that is odd. This is working for me with PPro CC2014 (8.2).
Trent Happel
Adobe
Premiere Pro -
Hirum Horkweller
June 5, 2015 at 5:59 amGlitch then, thanks for letting me know. I’ll run the updater.
– H
Hirum Horkweller
June 5, 2015 at 6:18 amYeah that’s what I’ve been doing. I’m fairly certain it must have been a glitch. Running an update now and will report back.
– H
Hirum Horkweller
June 5, 2015 at 6:52 amOK So I am now running the latest version: 2014.2, 8.2.0 (65) Build
Same problem. If I type (on the numeric pad) +10 (or anything for that matter) and press enter nothing happens.
However, if I click in the timecode window first, and then type +10 and press enter, it moves me ten frames ahead.
Can anyone else confirm this? This is so frustrating.
– H
Alex Udell
June 5, 2015 at 1:17 pmis any object in the sequence selected?
if so, it might think you are trying to move that object….
just a guess…
Alex Udell
Editing, Motion Graphics, and Visual FX -
Andrew Kimery
June 5, 2015 at 3:33 pmFWIW, I just tried it on my machine (latest build of PPro) and just typing numbers in (+10, -45, etc.,) on the numeric keypad moves the playhead around.
