Activity Forums Apple Final Cut Pro Legacy Move on Photo, Image disappears
  • Move on Photo, Image disappears
    Posted by Gregory Uhrin on June 7, 2010 at 2:19 pm
    I have a photo, put in a key frame to start a move (Zoom, pan or tilt), move along the time line, adjust framing, put in another key frame then play. Still image up to key frame is fine, image disappears during move to next key frame, still image is fine after key frame. What gives?
    Todd Gillespie replied 16 years, 2 months ago 2 Members · 1 Reply
  • Todd Gillespie
    June 7, 2010 at 5:30 pm
    It sounds like you’ve created a keyframe that takes the photo off screen.
    Try making a copy of the clip, resetting the keyframes and start adjusting in smaller steps, then see if you notice the photo flying off screen.
    It’s a common problem with FCP to ‘think’ you’re making adjustments to a clip that are not really affecting it.
    Good Luck,
    Todd at UCSB
    Television Production
