Activity Forums Adobe After Effects Expressions Move Null to location based on slider
  • Move Null to location based on slider
    Posted by Lukasz Pason on January 22, 2015 at 12:57 am
    I want a slider to control the position of a null based off the coordinates of other layers. Now, I think I have the base structure of the expression but I may be a long way off as wel…. Help if you can.
    Cont1 = Cont1Mark[0,1];
    Cont2 = Cont2Mark[0,1];
    Cont3 = Cont3Mark[0,1];
    Cont4 = Cont4Mark[0,1];
    Cont5 = Cont5Mark[0,1];
    Cont6 = Cont6Mark[0,1];
    ContSel = SliderControl value
    if { ContSel = (1)
    value = Cont1
    else {
    [0,1]
    if { ContSel = (2)
    value = Cont2
    else {
    [0,1]
    }if { ContSel = (3)
    value = Cont3
    else {
    [0,1]
    }if { ContSel = (4)
    value = Cont4
    else {
    [0,1]
    }if { ContSel = (5)
    value = Cont5
    else {
    [0,1]
    }if { ContSel = (6)
    value = Cont6
    else {
    [0,1]
    Motion Designer / DJ / Father
    http://www.lukaszpason.com
    http://www.krop.com/lukasz
    Lukasz Pason replied 11 years, 7 months ago 3 Members · 12 Replies
  • 12 Replies
  • Dan Ebberts
    January 22, 2015 at 1:26 am
    That seems like a lot of code for whatever you’re doing. What is in the array Cont1Mark ?
    Dan
  • Lukasz Pason
    January 22, 2015 at 1:33 am
    Here’s what I finally came up with but the null I want to move to those positions isn’t actually moving. Also, Having it actually slide instead of jumping to positions would be ideal.
    Cont1 = thisComp.layer(“Cont01”).transform.position;
    Cont2 = thisComp.layer(“Cont02”).transform.position;
    Cont3 = thisComp.layer(“Cont03”).transform.position;
    Cont4 = thisComp.layer(“Cont04”).transform.position;
    Cont5 = thisComp.layer(“Cont05”).transform.position;
    Cont6 = thisComp.layer(“Cont06”).transform.position;
    ContSel = thisComp.layer(“AUTO SCRIPT CONTROLLER – CONTINENT”).effect(“Slider Control”)(“Slider”);
    if (ContSel = (1)){
    value = Cont1
    else {
    [960,540]
    if (ContSel = (2)){
    value = Cont2
    else {
    [960,540]
    if (ContSel = (3)){
    value = Cont3
    else {
    [960,540]
    if (ContSel = (4)){
    value = Cont4
    else {
    [960,540]
    if (ContSel = (5)){
    value = Cont5
    else {
    [960,540]
    if (ContSel = (6)){
    value = Cont6
    else {
    [960,540]
  • Dan Ebberts
    January 22, 2015 at 2:43 am
    You need to string those else clauses together like this:
    if (ContSel == (1)){
    value = Cont1
    }else if (ContSel == (2)){
    value = Cont2
    }else{
    [960,540]
    but I think I’d do it this way:
    ContNames = ["Cont1","Cont2","Cont3","Cont4","Cont5","Cont6",];
    ContSel = thisComp.layer("AUTO SCRIPT CONTROLLER - CONTINENT").effect("Slider Control")("Slider");
    try{
    thisComp.layer(ContNames[Math.round(ContSel)-1]).transform.position;
    }catch(err){
    [960,540]
    Dan
  • Lukasz Pason
    January 22, 2015 at 4:07 am
    I was cycling home and thought of that exact thing, I need to set up a string! Nice to see that my coding is starting to get better. No comparison but it feels good.
    Your solution, I didn’t know you could set up a series of names in a variable! Great piece of info to know. I’m not familiar with the ‘try’ though… Is it literally just saying to try and use what the input from the slider is? That’s pretty cool if it is.
    Last question for you. Is there a way to modify this so that the null actually slides into position with ease?
  • Dan Ebberts
    January 22, 2015 at 5:08 am
    The try/catch construct is to keep the expression from breaking if the value of the slider goes negative or becomes larger than the size of the name array.
    From where? The previous position? Possible, but not simple and very dependent on how you set things up.
    Dan
  • Lukasz Pason
    January 22, 2015 at 5:23 am
    Thanks for the info and help Dan! I didn’t think it would be easy to make the null move from spot to spot rather than just jump to it. Maybe another day. =)
  • Dan Ebberts
    January 22, 2015 at 5:29 am
    The expression would need to be able to figure out the previous and next values of the slider. If you have the slider controlled by keyframes it would be fairly straightforward, but there would be a bit of code involved.
    Dan
  • Lukasz Pason
    January 23, 2015 at 5:42 pm
    I am actually key framing the slider in this instance. I do have a question, there seems to be a frame of lag, is that something that is intentional in the code?
  • Dan Ebberts
    January 23, 2015 at 5:54 pm
    Which code?
    Dan
  • Lukasz Pason
    January 23, 2015 at 5:55 pm
    The one you had suggested. =)
    try{
    }catch(err){
    [960,540]
