Activity Forums Apple Final Cut Pro Legacy Move Media 100 Files to Final Cut
  • Move Media 100 Files to Final Cut
    Posted by Adam Bagni on May 10, 2010 at 10:59 pm
    Hey guys… I just went though a major upgrade… from Media 100 8.2.3 to Final Cut Pro 7.0.2.
    What’s the easiest way to move all the files in my bin from Media 100 to Final Cut?
    Please lay it out for me step-by-step, as I’m a bit of a novice.
    Thanks so much for the help!
    Tahoe Todd replied 15 years, 5 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    May 11, 2010 at 2:28 pm
    Choose file/import/files (or folder) and import them into an FCP project. They may or may not work actually if they use a proprietary codec… if you can open them in QuickTime, any wierdness can be fixed so they DO work in FCP.
    Welcome BTW to FCP Land..
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Tahoe Todd
    March 11, 2011 at 4:23 pm
    Hi all:
    I just moved into Final Cut (finally) from the latest version of Media 100 suite (10.6). Brought a timeline over from M100 for the first time (exported the XML) and I’m seeing a pretty severe color shift in the media…most of the scenes are somewhat “washed-out” looking compared to how they looked in M100. I have a high-end HD monitor that is setup correctly. Any experience with this?
  • Tahoe Todd
    March 11, 2011 at 4:48 pm
    Hi all:
    I just moved into Final Cut (finally) from media 100 suite. Brought a timeline over from M100 and notice a pretty severe color shift in the media…most of the scenes are somewhat “washed-out” looking. I have a high-end HD monitor that is setup correctly. Any experience with this?
