Activity › Forums › Adobe After Effects › Move layer on the basis of the keyframe-position
  • Move layer on the basis of the keyframe-position
    Posted by Sander Van pelt on November 9, 2020 at 9:00 am
    Hello everybody,
    I have multiple layers. Every layer, except the first one, starts with an opacity of 0 percent and these have an opacity of 100 percent after several moments.
    How can I move these layers to the end of the layer beneath if the opacity is 100%?
    For example;
    Layer A has a duration of 10 seconds, layer B has a duration of 5 seconds and has an opacity of 100% after 2 seconds. Layer B must therefore start after 8 seconds and be 100% at the end of layer A. Layer C must do this again at layer B after x seconds etc.
    Is there a keybord shortcut for this?
    Thanks for your help
    Graham Quince replied 5 years, 10 months ago 2 Members · 1 Reply
  • Graham Quince
    November 14, 2020 at 2:50 pm
    Check out Animation > Keyframe Assistant > Sequence Layers
    It’s been a while since I needed to use it, but I think that is what you’re looking for.
