Activity Forums Adobe After Effects Expressions Move layer from fixed position to random position, within range
  • Move layer from fixed position to random position, within range
    Posted by Kyle Hamrick on May 26, 2010 at 4:03 am
    Hey all,
    Got an expression problem I can’t quite wrap my head around.
    I’ve got an animation where groups of people icons are multiplying exponentially. It’s getting complex very quickly, and I’d love to help automate my workflow a little and let the expressions do the heavy lifting. I’m close, but haven’t quite gotten it working. Figured I’d see if anyone else might be able to take a stab at this.
    The layers in question spawn at [0,35,0], then need to move, over 30 frames beginning at the layer’s in point, to [random (-30,30), 35, random (-20,-80)], where it will stay for the rest of the comp.
    I’ve gotten results somewhat close to what I need by adapting parts of this original expression from Motionscript:
    segMin = .3; //minimum segment duration
    segMax = .7; //maximum segment duration
    minVal = [0.1*thisComp.width, 0.1*thisComp.height];
    maxVal = [0.9*thisComp.width, 0.9*thisComp.height];
    seedRandom(index,true);
    segDur = random(segMin, segMax);
    seed = Math.floor(time/segDur);
    segStart = seed*segDur;
    seedRandom(seed,true);
    startVal = random(minVal,maxVal);
    seedRandom(seed+1,true);
    endVal = random(minVal,maxVal);
    ease(time,segStart,segStart + segDur, startVal, endVal);
    …But that’s designed to repeat. Expressions dealing with time have always somewhat tripped me up, and I can’t seem to figure out what I’m missing.
    I’d love to be able to tie each random min/max value to a respective master slider, allowing me to easily control the density of this crowd. I can’t imagine a way to build an expression without still having that pickwhip option, but thought I’d make it known, at least.
    Any suggestions?
    EDIT: I’ve got this ALMOST working, by using the “Separate XYZ Position” Preset, and applying this to one dimension:
    segDur = 1;
    seed = index;
    segStart = inPoint;
    startVal = 0;
    endVal = effect(“X value”)(“Slider”);
    Being able to compile all dimensions into one position expression would be nice, though.
    Kyle Hamrick
    Editor/Motion Graphics Artist
    http://www.kylehamrick.com
    Kyle Hamrick replied 16 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 26, 2010 at 4:32 am
    Something like this maybe:
    moveFrames = 30;
    startPos = [0,35,0];
    endPos = random([-30,35,-20],[30,35,-80]);
    ease(time,inPoint,inPoint+framesToTime(moveFrames),startPos,endPos)
    Tying the min and max x and z values to sliders should be pretty straight forward.
    Dan
  • Kyle Hamrick
    May 26, 2010 at 4:39 am
    Thanks for the response Dan. Definitely more elegant than my solution.
    Your post just barely beat me submitting my edit saying that I’d gotten it working. =)
    Mine is still using my earlier expression nested into the “Separate XYZ” effect, but it’s just as easy to copy/paste that. I was outlining my post a little more clearly in the hopes that it’d be helpful for someone else in the future.
    Between your answer and mine, I think this thread has now served its purpose in that respect.
    Thanks again!
    Kyle Hamrick
