Activity › Forums › Adobe After Effects › move keyframe(s) to current time shortcut?
Posted by Mo on April 12, 2007 at 6:24 amIs there a shortcut to move one or more selected keyframe(s) to the current time? I have found most of the shortcuts that I need but didn’t quite see this one.
Mo replied 19 years, 5 months ago 3 Members · 4 Replies -
Mike Clasby
April 12, 2007 at 7:47 amI dunno one for that (maybe someone else does), but this is pretty quick:
“to move one or more selected keyframe(s) to the current time”
Ctrl C, Delete, Ctrl V
I’m assuming you don’t want to drag said keyframe (Shift puts it exactly on the spot with the drag).
Mo
April 12, 2007 at 10:44 amthanks for your reply. yeah that could work but if i have like a lot of keyframes all staggered and i just want them lined up at one point, it’s kind of a pain. you can line up your multiple layers with “[” or “]” for example, so i thought there must be one for keyframes but maybe not.. i dont know. anyhow else know?
m
Jim Kanter
April 12, 2007 at 3:00 pmAE can’t do what you want (similar to an Extend Edit in Final Cut Pro). Try sending feedback to Adobe.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
