Activity Forums Adobe After Effects move keyframes between two key frames
  • move keyframes between two key frames
    Posted by Joe Mole on August 22, 2014 at 7:56 pm
    A long time ago I did a project where I had tons of keyframes between two keyframes. The keyframes in-between were smaller dots on the timeline and if I grabbed one of the end keyframes the keyframes in-between would move sort of like a rubber band. I’m trying to do this again in order to control the animation time between the start and end of two keyframes. Does anyone know what I’m talking about and how to do this? Thanks a ton!
    Todd Kopriva replied 12 years, 1 month ago 3 Members · 2 Replies
  • Kevin Camp
    August 22, 2014 at 8:03 pm
    you can simply select all the keyframes (or a group of them) and then option-drag (or alt-drag) the first or last keyframe and the select keys will ‘redistribute’ accordingly.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Todd Kopriva
    August 22, 2014 at 8:10 pm
    Kevin is correct.
    Regarding what you were seeing in your previous project: roving keyframes.
    After Effects team blog
