Activity Forums Apple Final Cut Pro Legacy Move from AVID to FCP
  • Move from AVID to FCP
    Posted by Wendell Davis on September 12, 2006 at 1:12 pm
    1. I am trying to install an AVID 8 bay LVD dual SCSI system on a Mac G5. With the LVD turned off the G5 starts perfectly. Starting with the LVD system turned on – I get an immediate crash telling me to restart.
    Any ideas on how to get the drives up and running so I can see them on my system.
    2. I have 80 gig drives in the bays. Without paying AVIDs prices, can I replace the drives with other larger SCSI drives?
    Really appreacite the help.
    Wendell
    G5, 2.5g AVID SCSI controller. NOT running the AVID on this machine. Just want to use the drives for FCP.
    Wendell Davis replied 20 years ago 6 Members · 14 Replies
  • 14 Replies
  • Jerry Hofmann
    September 12, 2006 at 1:17 pm
    How was the array formatted? for Mac? I’d think you can replace the drives without any problem…
    Jerry
  • Wendell Davis
    September 12, 2006 at 1:28 pm
    Thanks Jerry for the quick reply.
    This raid was formatted for MAC 9 in to two banks. Had been working perfectly on my G4. I’ve now gone to FCP5 fulltime and would love to have the dual SCSI performance.
    Wendell
  • Nick B
    September 12, 2006 at 2:27 pm
    “AVID SCSI controller”
    Just a guess but that might be the problem, maybe update the drivers for the controller card to work on a G5, or replace card with an adaptec card
  • Jerry Hofmann
    September 12, 2006 at 2:42 pm
    I’d reformat it using Apple’s Drive Utility even if you can get it to mount, and also check into the host adapter you’re using… has to be compatible with your G5… could be it needs replacing. ATTO is the ONLY way to go here IMHO…
    Jerry
  • Jerry Hofmann
    September 12, 2006 at 2:43 pm
    It was originally formatted with software from Avid?
    Jerry
  • Wendell Davis
    September 12, 2006 at 3:06 pm
    I believe it is the controller card – shows up under the About this Mac. But can’t find any drivers to support OS X. It is an Adaptec card model ADPT. 39160.
    What ATTO card might you suggest. Hate to thow away a heft hardy RAID system. Hoping to put in 200 or more gig drives in each bay if I can get it running.
    By the way they don’t show up at all in Disk Utility to be able to reformat.
    Wendell
  • Steven Gonzales
    September 12, 2006 at 5:59 pm
    It seems the last driver for the 39160 is a 1.3beta1 dated 8 Jan 2004. Here’s it’s location:
    https://www.adaptec.com/en-US/downloads/macos/macos_x?productId=APD-39160&dn=PowerDomain+39160
    If that doesn’t work, I think the ATTO UL4D should substitute.
    https://www.attotech.com/ultra4D.html
  • Wendell Davis
    September 12, 2006 at 9:39 pm
    Thanks guys. I can get a single SCSI drive to work but not the AVID Raid…. bumbed out. Now that I’m retired only do work for non-profits I don’t the 3-4k to buy new raids… My goal had been to upgade the drives in the AVID LVD dock… but alas.
    Appreacite all your ideas and work trying to get the correct driver.
    Wendell
  • Wendell Davis
    Wendell
  • Kevin Monahan
    September 12, 2006 at 11:10 pm
    Check for SCSI ID numbers and make sure they are all different, don’t forget to include the SCSI card’s ID. Also make sure your SCSI chain is terminated.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
