Activity › Forums › Maxon Cinema 4D › Move dynamic cloth
  • Move dynamic cloth
    Posted by Davor Kampel on January 8, 2014 at 6:57 pm
    Hi all! I have a cloth kite in my scene and it’s flying moved by the wind, it also has a little cloth tail. It’s attached to a string, wich is supposed to be held by a boy, and it should suddenly pull the boy from his position (the boy isn’t rig, it’s actually a group of objects). So how do I move the position of the kite (while keeping it’s dynamics) along with the boy? Thanks
    Adam Trachtenberg replied 12 years, 8 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    January 9, 2014 at 4:08 am
    Use a cloth belt tag.
  • Davor Kampel
    January 25, 2014 at 7:03 pm
    I am using the belt tag, but when I try to animate the position of the kite the cloth tail stays in place even tho it’s in group with the kite, I want it to move with the kite.
  • Adam Trachtenberg
    January 27, 2014 at 11:19 pm
    So you have two cloth systems in your scene: one for the kite and another for the tail? If I understand your setup, you would belt the kite to the string and then belt the tail to the kite. The hierarchy is irrelevant.
