Activity Forums Adobe After Effects Expressions Move an object along the x axis over a designated number of frames
  • Move an object along the x axis over a designated number of frames
    Posted by Mike Tosetto on May 31, 2012 at 2:15 am
    Hi there.
    I’m a bit stuck with the solution for this. I have a number of objects on a grid and want to move them tighter together as I pull the camera back.
    I’m hoping some kind of expression might do the trick.
    I need to move an object along the x axis for say 100px over a period of 25 frames.
    I’ve got this so far but unfortunately this creates continuous movement.
    Any help as always is much appreciated.
    Cheers
    Mike
    x = (time / thisComp.frameDuration) * 10;
    value + [x, 0]
    miketosetto dot com | bestiacollective dot com
    Mike Tosetto replied 14 years, 3 months ago 2 Members · 4 Replies
  • Dan Ebberts
    May 31, 2012 at 2:39 am
    Something like this:
    tStart = 1; // start move at 1 sec.
    numFrames = 25; //move for 25 frames
    dist = 100; //move 100 pixels
    x = linear(time,tStart,tStart+framesToTime(numFrames),0,100)
    value + [x,0]
    Dan
  • Mike Tosetto
    June 1, 2012 at 12:45 am
    Dan, I mean this with the absolute utmost respect, you are a freak with this stuff. Thanks so much.
    Thanks so much.
    I don’t know if this next question is pushing the friendship, but is it possible to ease with expressions?
    Thanks again Dan 🙂 🙂 🙂
  • Dan Ebberts
    June 1, 2012 at 12:54 am
    In the previous example, just change “linear” to “ease” (or “easeIn” or “easeOut”). See the Interpolation Methods section in the expressions chapter of AE Help.
    Dan
  • Mike Tosetto
    June 1, 2012 at 1:20 am
    Ah yes of course, shouldn’t have missed that. Thanks again Dan. It works a treat
