Activity Forums Adobe Illustrator Move a point (vector) on the same path
  • Move a point (vector) on the same path
    Posted by Stephan Dube on January 6, 2009 at 9:41 pm
    Hello
    I had a quick question
    In Illustrator CS 4 is there a way I could move an achor point (vector) from a path but it follows the path?
    For example if I create a 45degrees line and I want to take the furthest point and move it to the same angle (45 degrees) but make the line shorter how would I do this?
    thanks
    cheers
    stephan
    Stephan Dube replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
