Activity Forums Adobe Premiere Pro .mov with codec type xdcam hd422 1080i50
  • .mov with codec type xdcam hd422 1080i50
    Posted by Stanley Seng on September 1, 2012 at 4:11 pm
    Hi, can premiere pro cs5.5 or cs6 produce export .mov file with codec type xdcam hd422 1080i50? I have try to search from premiere and encoder , under this codec the file produce is in mxf format.
    My customer is a satellite tv station require my video to be delivered in xdcam hd422 1080i50 wrapp in mov file.
    I use p pro c55 for editing. Footage was taken by 5d2 in 29.97 fps hd1080.
    Thank you
    Dennis Radeke replied 13 years, 12 months ago 4 Members · 5 Replies
  • Andrew Smith
    September 1, 2012 at 9:45 pm
    Have they ever had it in a .mov container?
    I’m not seeing anything that says you can stick the HD422 into a .mov.
    You might want to also ask over on the Sony website if a .MOV container will support the hd422 footage.
    The only XDCAM that I see that can be used in a .mov is a JVC’s XDCAM EX.
  • Ken Mitchell
    September 2, 2012 at 1:28 pm
    I am pretty sure that the.mov xdcam is MAC only. Just like their HDV and apple intermediate codec.
  • Andrew Smith
    September 2, 2012 at 2:59 pm
    Ken, does that include the 422?
  • Ken Mitchell
    September 2, 2012 at 6:07 pm
    It would be all.mov xdcam ,apple hdv and apple intermediate codecs.
    xdcam is ingested into final cut 7 using the log and capture and it is
    converted to prores or apple xdcam.mov before it is put into the timeline. ****I did do a test and although quicktime cannot play the files you can input the .mov xdcam files into Premiere CS6 on the PC and they will play but only in Premiere and AfterEffects.CS6. Don’t know about CS5.
  • Dennis Radeke
    September 3, 2012 at 11:52 am
    Hi there,
    You cannot export XDCAM as a .mov unless you are a) on a Mac b) have FCP or similar loaded onto the system. If you’re on Windows, I can’t think of anything off the top of my head.
    Happy Labor Day,
    Dennis – Adobe guy
