Activity Forums VEGAS Pro .mov w/ Alpha
  • .mov w/ Alpha
    Posted by Yuan Soong on February 16, 2011 at 7:48 pm
    Using Vegas 10.0c (build 470)
    a HD 1080-60i (1920×1080, 29.970 fps) project with 6 images (a simple test)
    Rendering using QuickTime7, VASST(GrafPak) HD 1280×720-30p Video Overlay with:
    Field order: None (progressive)
    Pixel aspect ratio: 1.000
    Video format: PNG
    Compressed depth: 32 bpp
    Quality: High
    when pressing Save, Render completes in seconds and only a .mov.sfl is created. No .mov file created.
    What am I doing wrong?
    Thanks.
    Edward Troxel replied 15 years, 7 months ago 3 Members · 6 Replies
  • Mike Kujbida
    February 16, 2011 at 7:54 pm
    Saving only saves the project file (*.veg) so make sure you select Render instead.
  • Yuan Soong
    February 16, 2011 at 8:03 pm
    That’s what I just said. Save (from the File Render As) dialog … all that is created is a .mov.sfl file. Where’s the .mov file?
  • Yuan Soong
    February 16, 2011 at 8:32 pm
    I also tried Video for Windows (*.avi). However, in the Custom Settings dialog, the line:
    —> Render alpha channel (uncompressed video formats only)
    is disabled. Thus, I can’t render an avi file with an alpha channel.
    How do I get the alpha channel line enabled?
    Thanks.
  • Mike Kujbida
    February 16, 2011 at 8:36 pm
    Make sure you don’t have a tiny loop region selected, especially if the Render loop region only box is selected in the Render dialog.
    Either make sure all events are selected or deselect this option.
  • Yuan Soong
    February 16, 2011 at 11:09 pm
    It makes no difference if a region is selected or not.
    1. Why is .mov.sfl file created and the .mov file missing?
    Also, if I use File Render As, Video for Windows (*.avi), Custom … the Render Alpha channel option is disabled.
    2. How do I get this option enabled?
  • Edward Troxel
    February 17, 2011 at 1:48 pm
    If you’re going to an AVI file, you choose “Uncompressed” for the alpha option to become active.
    Edward Troxel
    JETDV Scripts
