Activity › Forums › Compression Techniques › mov to mpeg
  • Posted by Uwishbiff on December 14, 2005 at 12:21 am
    I’m looking for an app to convert a mov to a mpeg-1 file…I know that its possible using Cleaner. Unfortunately, I don’t have a copy of Cleaner. I do however have FCP and Compressor. Maybe there is a free solution to this or maybe its something i’m overlooking that I might be able to do with my existing software.
    Thanks to anyone who might be able to offer any help!
    uwishbiff
    Charles Simonson replied 20 years, 9 months ago 3 Members · 2 Replies
  • Phil
    December 14, 2005 at 3:34 pm
    yes, compressor allows you to export out using mpeg 1…in the apple presets, the MPEG-1 DVD 1.85 will give you an extensino of .m1v, so just make a new custom one, that has the extension .mpg
    thats it!
  • Charles Simonson
    December 21, 2005 at 12:09 am
    I don’t believe some versions of Compressor will mux MPEG-1. I think 1.2.1 did, but versions prior to that could not. If for some reason you are forced to use an earlier version, and can only output elementary MPEG-1 streams, then I’d recommend BitVice Helper or MPEG StreamClip (both free). There is also ffmpegX ($15) which will do a better job encoding the video to MPEG-1 than Compressor. But it can be difficult to use for some.
