Activity › Forums › Compression Techniques › mov to mpeg-ts?
mov to mpeg-ts?
Posted by Dirk Teubler on December 19, 2006 at 3:31 pmhi folks,
is it possible, to convert a .mov-file into an mpeg-ts-file?
i use mac os x 10.4.8
are there an prog. that could make it for me?Ed Dooley replied 19 years, 9 months ago 5 Members · 6 Replies -
Tom Brooks
December 20, 2006 at 2:40 pmWhat’s an MPEG – ts file?
Are you referring to the VIDEO_TS and AUDIO_TS folders that are found on a DVD? If so, what you want is a program to make a DVD from a .mov file. Use Apple’s DVD Studio Pro or Adobe’s Encore DVD or even one of the Roxio programs like Easy Media Creator. They’ll all do it in different ways and with different amounts of complexity. -
Boyce Johnson
December 21, 2006 at 2:10 amIf you’re referring to an MPEG2 Transport Stream then Compressor will do it for you.
Tom Brooks
December 21, 2006 at 3:44 amIs the format that Compressor makes used for broadcast purposes?
Final Cut Studio, FCP 5.1.2, After Effects 6.5 Pro, Quicktime 7.1.3, G5 Quad 2.5, Kona-LHe V3, 4.5GB RAM, Nvidia GeForce 7800-GT, G-RAID 2x1TB FW800.
Dirk Teubler
December 21, 2006 at 8:58 amthx, for the info.
i tried it first with ffmpegx and this didn’t match, i hope that compressor will do it.
and yes, it is an mpeg-transport stream including audio, for tv on handy broadcast. -
Charles Simonson
December 21, 2006 at 6:19 pmThe best options for MPEG-2 transport streams on the mac are MainConcept and Epsiode. You can also take a MPEG-2 program stream and convert it to a TS by using MPEG Streamclip, but I have had issues in the past with this for certain types of encodes.
Ed Dooley
December 22, 2006 at 8:50 pmCompressor won’t do a high enough bit-rate for broadcast.
Ed[Tom Brooks] “Is the format that Compressor makes used for broadcast purposes?”
