Activity › Forums › DVD Authoring › .mov to MPEG-4 AVC elementary stream h264 codec for Blu-ray authoring
  • .mov to MPEG-4 AVC elementary stream h264 codec for Blu-ray authoring
    Posted by Elaine Trotter on November 5, 2012 at 5:52 pm
    Hi all,
    Editing on MAC – FCP7, exporting 1920 x 1080 prores .mov files.
    Authoring on PC – Avid DVDit Pro HD (works OK for Blu-ray)
    Problem: Mov files have different gamma looks on PC and Mac.
    Want to convert .mov file to MPEG-4 AVC elementary stream (h264 coded) on Mac and then import that
    file into DVDit Pro HD on the PC.
    Reasons for this conversion –
    1. avoid the .mov gamma look difference between Mac & PC by doing conversion on Mac first.
    2. The MPEG-4 AVC elementary stream (h264 codec) is Blu-ray compliant video and will not requite further transcoding within DVDit Pro HD.
    Can anyone recommend conversion/encode software that will accomplish this?
    Thanks….
    Daniel Ludwig replied 13 years, 10 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    November 9, 2012 at 12:29 pm
    if you want to encode H264 on mac you´ve only got a few options:
    – adobe media encoder
    – mainconcept reference
    – apple compressor
    – episode pro
    if you use adobe media encoder, you might better look at the black level & brightness if you are using CS6. it´s got a bug, i don´t know if they fixed it now. CS5 and 5.5 was ok.
    mainconcept the same, could not create original color.
    I would have a look at compressor or episode
    cheers
    danny
