Activity › Forums › Adobe Premiere Pro › .mov show up with only white video and no sound on import to Premier Pro v2
  • .mov show up with only white video and no sound on import to Premier Pro v2
    Posted by Nik Crosina on August 29, 2006 at 12:12 pm
    Not sure if this Off Topic here, or where it would better fit in the multitude of forums here on the Cow.
    My problem is:
    I got to transfer video from the Mac to PC. The files come as a .mov file, but none of my PCs can read them propoperly. The right application (Quicktime) will open but instead of proper playback I only get playabck of white video and no sound. Same happens if I import to Premier Pro v2.
    I occassinaly get the error message that Quicktime is missing some codecs (the most likely problem here in my opinion) but tghe included link takes me to a list of QT add ons, none of which seem really relevant to my situation, and the ones I tried certainly don’t do anything to change the problem.
    Does anyone know what’s happening here?
    Nik
    Nik Crosina replied 20 years, 1 month ago 2 Members · 2 Replies
  • Mike Velte
    August 29, 2006 at 12:20 pm
    Premiere wont handle QT Reference files. Suggest exporting from the Mac as QT DV codec.
  • Nik Crosina
    August 30, 2006 at 2:13 pm
    Thanks, Mike,
    I’ll try that – is sounds like the only possible solution in this case!
    Nik C
