Activity › Forums › Apple Final Cut Pro Legacy › Mov or mp4? Does it matter?
Posted by Kent Beeson on October 4, 2006 at 8:12 pmHi
What’s the diff between making a web video at 320 x 240 as an mov or an mpeg4 file? Does it matter? I usually use H264 for web video but do I have to?
KBDavid Roth weiss replied 19 years, 11 months ago 2 Members · 4 Replies -
David Roth weiss
October 4, 2006 at 8:25 pmIn theory H264 delivers high compression rates and thus smaller file sizes, but with excellent quality. So, only use H264 if you want the combination of small file size and excellent quality.
DRW
Kent Beeson
October 4, 2006 at 8:45 pmThanks for reply – what I meant was (and I should have stated it) I normally use H264 with mpeg 4, and I wonder what if anything is the diff between doing that and using H264 as an mov file (instead of mpeg 4)…I’m rendering an mov as we speak, making an mov at 320 x240 using H264 to see what it looks like and what file size is, but the rendering takes SO long, I wanted to get some pro feedback on the subject while I’m waiting.
KB -
Kent Beeson
October 4, 2006 at 8:58 pmOK the mov was 17.4 mb and the mpeg 4 was 4.4 mb – with no vastly different quality. So I’ll use H264 mpeg4.
KB -
David Roth weiss
October 4, 2006 at 9:03 pmExcellent Kent!!! I was going to suggest that you try it out to compare, thats always best to see these things with your own eyeballs.
DRW
