Activity › Forums › Adobe After Effects › .mov making last frame stay through timeline(AE CS4)
  • .mov making last frame stay through timeline(AE CS4)
    Posted by Ben Marker on December 10, 2008 at 5:29 pm
    I have a newb question that I can’t figure out. I have a depth of field effect I”m working on and I have imported a .mov. I would like to know how to make the very last frame of my .mov stay for the duration of the entire composition, even after the video is finished playing. Do I need to render the last frame separately and use a jpeg? I would assume there’s some way in AE to do it.
    I have no problem doing this with images, simply extend the end of the image’s timeline. How do I do this with a .mov?
    James Lawson-smith replied 16 years, 11 months ago 3 Members · 3 Replies
  • John Cuevas
    December 10, 2008 at 5:42 pm
    You want to enable time remapping. cntl-alt-t or under ‘layer’/’time’.
    When enabled it will put keyframes at the first and last frame. Change the last keyframe to a hold keyframe, select &”cntl-alt-h”. Now just extend the layer to end of composition.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Ben Marker
    December 10, 2008 at 6:06 pm
    Excellent! Thank you! What are some other forums I can check out for AE stuff? CCow seems to be a little limited on searching etc like phpBB sites.
  • James Lawson-smith
    October 28, 2009 at 2:42 pm
    Thank you very much Dave you helped me out loads with that one. Thanks again!
    http://www.boofly.com
