Activity › Forums › Adobe Media Encoder › .mov looks crazy when trying to use in media encoder
  • .mov looks crazy when trying to use in media encoder
    Posted by Leo Thom on October 8, 2014 at 12:39 am
    I’ve been given a whole load of .mov files by someone and I need to use media encoder to convert to .avi so that I can run this deflicker filter – https://www.compression.ru/video/deflicker/index_en.html which doesn’t support .movs.
    Okay so anyway, the problem I’m having is that when I bring in any .mov, whatever the output settings much of the video goes crazy with block colour – see attached. The bottom is what it should look like, and does for a few seconds, and then it flicks to the crazy block over and over.
    I’ve never come across something like this, and even tried different .movs I have which don’t bring up that problem. I’m guessing it’s a problem with how it’s been produced before I received it?
    many thanks
    Jeff Coleman replied 11 years, 11 months ago 2 Members · 3 Replies
  • Leo Thom
    October 8, 2014 at 7:56 pm
    some more details here
    many thanks
  • Leo Thom
    October 8, 2014 at 10:34 pm
    Just realised it’s not just in media encoder but powerdirector, so must be for all video editing software?
    Here is a link to one of the short films if you fancy downloading and having a look – https://www.dropbox.com/s/w9wziuf2rgv8phq/Lecture%2022%20-%20Introducing%20Hypnosis_Exercise_Healthy_Nutritious_Foods.mov?dl=0
    many thanks
  • Jeff Coleman
    October 16, 2014 at 5:39 pm
    I’m on a Mac so I can’t help directly. Perhaps the following is helpful:
    1. Downloaded the above file from your link and it plays fine. I am able to convert that file to other formats without errors. I assume this is a source. So the source appears to be fine.
    2. I am able to convert that to .avi via MPEG Streamclip, but not able to confirm playback given conversion process used to playback .avi movies on a mac, but even that process seems unremarkable.
    3. Have you tried another application like MPEG Streamclip to make the .avi conversion? https://www.squared5.com/
    If MPEG Streamclip works then perhaps something is ill with AME; if Streamclip fails, then perhaps it is something on your PC.
    Your version of AME and information on your operating system might help others as well.
