Activity Forums Adobe Premiere Pro .mov incorrect FPS when imported into Premiere
  • .mov incorrect FPS when imported into Premiere
    Posted by Vanessa Appleby on September 1, 2009 at 5:43 pm
    Premiere has been singled handedly ruining my life for about 2 weeks now. I finally moved onto a new project and still things are going haywire.
    I was animating in Flash and exported a bunch of .mov files at animation compression with no audio. When I import them to Premiere the FPS are all incorrect except one file. They should all be 25 FPS, but they’re 12.35, 6.25, 5.00, 8.33 and all sorts of other crazy things. I exported EVERY .mov with the exact same settings. When I interpret footage to change the FPS back to 25, the clips are sped up and look horrible.
    I tried exporting .avi’s from Flash, but every time I try to drag them to my timeline in Premiere the program crashes! If anyone can offer suggestions as to how to deal with this I would be eternally greatful. Thank you!
    Vanessa Appleby replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
