Activity Forums Avid Media Composer .mov import Avidxpress
  • .mov import Avidxpress
    Posted by Wendell Davis on November 12, 2010 at 11:02 pm
    I gave a friend DV .MOV files I captured in FCP Studio. Her AvidXpress version 3.5.4 will not even see them let alone import them. Hr manuel says it can import .MOV. Would highly appreciate and suggestions.
    Michael Kammes replied 15 years, 10 months ago 4 Members · 5 Replies
  • Grinner Hester
    November 13, 2010 at 12:02 am
    If you export them as mov files using the animation codec or a Avid codec, she’ll be able to import them.
  • Wendell Davis
    November 13, 2010 at 2:26 am
    Thank you so much. Will give it a try. DOn’t have any AVID codecs that I know of in FCP5
  • Job Ter burg
    November 13, 2010 at 10:18 am
    Just download (for free) and install: https://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=372311
    My best guess is that you are using some codec on the FCP side that the receiving partner does not have on their system.
    When you install the Avid codec on your end, it will save them import time on their end, as .mov files in the Avid codec will fast import into Avid (as no transcoding would be required anymore).
  • Wendell Davis
    November 13, 2010 at 11:42 am
    Good morning Job. Thanks you so very much for your reply.. Especially so early in the morning. I will give it a try.
    Wendell
  • Michael Kammes
    November 21, 2010 at 2:07 am
    Hi Wendell:
    I recently wrote up how to perform a Fast Import correctly. Hope this may help!
    https://michaelkammes.com/encoding/avid-is-self-aware-fast-import/
    ~Michael
    .: michael kammes mpse
    .: senior applications editor . post workflow consultant
    .: audio specialist . act fcp . acsr
    .: michaelkammes.com
    .: michael A T michaelkammes.com
