Activity › Forums › Adobe After Effects › .mov files won’t load
  • Erik Pontius
    February 5, 2008 at 11:11 pm
    Can you give us a hint?
    What happens? Any error messages? Where did these QT files come from? What CODEC are they using? Will that play in the QT player?
    Erik
  • Reggie Spires
    February 5, 2008 at 11:47 pm
    It was working fine the last time I opened the project.
    After effects error “CJ115.mov” cannot be opened, it may be an unsupported format
    86 :: 25
  • Erik Pontius
    February 6, 2008 at 12:01 am
    I think the majority of problems between AE and QT 7.4 has been during rendering. Most commonly rendering stops and errors after something like 10 mins of rendering.
    Does the same file open in QT by itself?…outside of AE?
    Erik
  • Reggie Spires
    February 6, 2008 at 12:14 am
    Yes works fine in QT .. I am on a PC so I went back to the latest QT ver
  • Reggie Spires
    February 6, 2008 at 12:32 am
    they are stock footage that worked fine a month ago.. .mov
  • Erik Pontius
    February 6, 2008 at 12:48 am
    You didn’t by any chance trim your source clip by a few frames and then run the autotrace for the super-tight junk matte?
    I’ve seen it to where it will trace the footage from the beginning of the source rather than the current in point of your source footage…causing the autotrace matte to be off by the “trimmed” number of frames.
    Erik
  • Reggie Spires
    February 6, 2008 at 1:18 am
    Uhhhhhh no
  • Reggie Spires
    February 6, 2008 at 1:53 am
    Got to be the quick time crap .. what is the latest fix..
  • Erik Pontius
    February 6, 2008 at 2:19 am
    Sorry…that was a response to a different post…
  • Reggie Spires
    February 6, 2008 at 2:41 am
    CRAP CRAP
