.mov file plays audio but no video
Posted by Shawn Bossick on December 17, 2013 at 6:55 pmHello!
I am trying to edit .mov files in Vegas Pro 12 that will not play the video files but will only play the audio files. In Quicktime, only the audio plays & in every other player I have the same thing happens, audio only no video. I have downloaded VLC player & the .MOV files play video & audio.
I need to know, how do I open these files in Vegas so I can edit them ?
Here is what movie inspector says about the files.
Format
XDCAM EX 1080i60 (35 mb/s VBR)
1628×916 millions
16-bit integer (Big Endian) Stereo 48.000 khz
Movie FPS 29.97
Normal size 1920 X 1080 Pixels
Current size 1628 X 916 PixelsThank you for helping me!
Shawn.
Matt Clara replied 11 years, 3 months ago 5 Members · 10 Replies -
Steve Rhoden
December 17, 2013 at 10:27 pmMost likely you gonna have to convert them using a conversion
software, then you can drop them in Vegas for editing.
Where did these files came from?Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
Shawn Bossick
December 17, 2013 at 10:42 pmHello Steve.
I’ve got it figured out a bit. The file is an XDCAM EX file. I have found a demo codec that works, https://www.calibratedsoftware.com/store/WindowsIndividualStore.asp
It cost $149.00 though. Now I’ve been reading about installing an SxS
device driver. I just tried installing it but no luck.Now I’m reading I may need an SxS Device Driver and SxS UDF Driver.
Got to admit I’m confused.I just need to import an XDCAM EX file into Vegas then edit. Do you know of a cheaper route then the $149.00 codec I listed ?
Thanks!! !! !!
Shawn.
John Rofrano
December 17, 2013 at 10:44 pmHow did your XDCAM EX get into a MOV container? They should be MP4 files and Vegas Pro supports this natively.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Shawn Bossick
December 17, 2013 at 10:54 pmHello John! And Steve!
I was handed the files from my church. They gave me an SD card, I have dumped all the info from the card to my computer but cannot get Vegas to open them. The audio plays on Vegas but no Video.
I’m stuck not knowing what to do ?
Any suggestions would be great!
Thanks!!
John Rofrano
December 17, 2013 at 11:21 pm[Shawn Bossick] “They gave me an SD card, I have dumped all the info from the card to my computer but cannot get Vegas to open them.”
That would have been a good time to use the XDCAM Explorer. 😉 You don’t just copy files to your PC. You should always import them using the Device Explorer or XDCAM Explorer.
What is the file extension of the files?
~jr
Shawn Bossick
December 17, 2013 at 11:58 pmUmm!
I did not know that. The file extension is .mov I tried renaming it to mp4 with no luck. I’m assuming I’ll have to take them back to get them converted.
Unless there’s something else ?
If not ?
Thanks John!!
John Rofrano
December 18, 2013 at 12:11 am[Shawn Bossick] “I did not know that. The file extension is .mov I tried renaming it to mp4 with no luck. I’m assuming I’ll have to take them back to get them converted.”
Yea, that was a last ditch effort. Since MP4 is a subset of the MOV container, you can usually rename MP4 to MOV and not have any problems but it doesn’t always work going the other way. 🙁
~jr
Steve Rhoden
December 18, 2013 at 12:14 pmIf its no big deal to take them back and import them using the
Device Explorer, that would be your easiest solution then.Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Mike Kujbida
December 18, 2013 at 12:24 pmI’ll give the same reply I did to your other related thread and that is to check out my replies in the How do I open an XDCAM file in Vegas? thread.
Matt Clara
May 29, 2015 at 12:58 pmI’m a couple years late here with a less than ideal solution, but VLC player can convert the file to several different formats. Does a pretty good job of it, too.
