Activity Forums Adobe Premiere Pro .mov dv to tape
  • .mov dv to tape
    Posted by Marcelokron on August 2, 2005 at 12:48 am
    Hi… I receive a external HDD with a lot of clips that was capture in FCP (.mov dv) and I just have to print to tape. There is any way to do that with no render in premiere pro 1.5???
    Thaks for any help!
    Blast1 replied 21 years, 1 month ago 5 Members · 5 Replies
  • Mike Velte
    August 2, 2005 at 11:11 am
    If your PC is fast enough, the DV.mov files mught play out to tape from the timeline without using the Export option which would require a rerender, but the DV editing mode is the only Project setting that will play out via firewire.
  • Steven L. gotz
    August 2, 2005 at 3:33 pm
    I believe that the only difference between a file captured with a Mac, and one captured with a PC is the header information. The data from the tape itself must, by definition, be identical.
    There are conversion programs, I believe, that can change out the header info for you. So no rendering.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Ken Adolph
    August 3, 2005 at 2:30 am
    Steven,
    do you have any names of these conversion programs? this is very critical for us as I have a new Axio system and am doing a lot of online for FCP people.
    I have found out in the last few days that either PPro or Axio reverses the fields in a QT DV file from FCP. You have to reverse field order on the clips in PPro to make it work. this is after opening the qt files in a 720×486 8bit uncompressed Axio project.
    Very frustrating!!!
    Ken Adolph
    Media Group
    Editor/Post Supervisor
    https://www.mg.ca
  • Steven L. gotz
    August 3, 2005 at 3:44 am
    https://www.focusinfo.com/corporate/pr_new/161003DVCS.htm
    Steven
  • Blast1
    August 3, 2005 at 11:46 pm
    Another conversion program thats not to expensive is ProCoder Express from Canopus ($60)
    https://www.canopus.us/US/products/procoder_express/pm_procoder_express.asp
