Activity Forums Apple Final Cut Pro Legacy mov doesnt work – not a movie file?
  • mov doesnt work – not a movie file?
    Posted by Nigel Askew on March 3, 2010 at 12:28 pm
    I’ve found a mov in our archive that wont play in quicktime (not a movie file) but will play in VLC. What can i do to get this file back?
    i did try searching but he keywords used are so general that i couldnt find anyone with the same problem
    thanks
    Nigel Askew replied 16 years, 6 months ago 2 Members · 5 Replies
  • Nigel Askew
    March 3, 2010 at 12:30 pm
    mpegstreamclip doesnt like it either…
  • Arnie Schlissel
    March 3, 2010 at 1:55 pm
    What codec is the movie? You may need to find an old codec to get it to play in QT. Or try to export from VLC to convert it to a QT codec that you can play.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Nigel Askew
    March 3, 2010 at 2:34 pm
    ‘get info’ says dvc-pal, linear pcm, which is the same codec as other files that play fine in quicktime.
    id like to avoid re-encoding it if at all possible.
  • Arnie Schlissel
    March 3, 2010 at 3:34 pm
    There’s clearly something wrong with the file. The best thing may be to bring it into something that can export or render it back out. Can you get it to work in AE?
    Arnie
  • Nigel Askew
    March 3, 2010 at 3:46 pm
    no, not in AE, FCP, Quicktime or MPEG Streamclip, but it does work in VLC…very strange, VLC doesnt have very broad options for exporting though, or re-wrapping…
