.mov Compression For A 10 x 10 Screen
Posted by Clay Dempsey on August 21, 2008 at 12:56 amIf I am wanting to use .mov files for my video presentation, what compression rate should I use so I won’t lose quality on a 10×10 screen?
Clay Dempsey replied 18 years ago 3 Members · 4 Replies -
Danny Hays
August 21, 2008 at 2:01 amWhat resolution is the source footage? Do you mean export as .mov or use .mov files in Vegas? Vegas supports fully customisable H.264 .mp4 files which open in Quicktime. You can change the extention to .mov and play with Quictime. With a 10 by 10 screen, the video won’t fill the screen without changing the output aspect ratio to 1 by 1. Danny
Clay Dempsey
August 21, 2008 at 2:13 amMy source files are avi, but the files are too big and take up too much ram on my midi controller (vj work). I want to output as .mov, but i don’t want to loose quality when i blow it up to 10 foot x 10 foot. I don’t see wehre you change to output ration to 1 by 1.
Douglas Spotted eagle
August 21, 2008 at 2:23 amjust to be clear:
avi is merely a package.
mov is merely a package.
you can have an uncompressed file packaged in an .avi or in a .mov.
you can have a hightly compressed file packaged in an .avi or .mov.
you can have the exact same file packaged in both containers, and the file size will be approximately the same. Render a file to DV in an avi package and then do the same thing with a Quicktime/mov file.
They’ll be nearly identical.
For VJ work, I’d recommend an .mp4 file, wmv file, or MPEG2 file.Douglas Spotted Eagle
VASSTCertified Sony Vegas Trainer
Aerial Camera/Instructor -
Clay Dempsey
August 21, 2008 at 3:24 amso a best quality mp4 will look correct blown up to 10 foot. that is pretty much all i am asking.
