Activity Forums Blackmagic Cameras Mounting MixPre-D Vertically – Question about Marco’s Rig
  • Mounting MixPre-D Vertically – Question about Marco’s Rig
    Posted by Matthew Sonnenfeld on December 5, 2013 at 5:50 pm
    Hey Marco,
    When I saw you at the Blackmagic Design show in NYC I saw that you had mounted you MixPre-D vertically using a V-Lock system. Might you be able to direct me to that system? I’m looking to make my rig a bit more compact.
    Matt
    Co-President at fourB Productions, Inc.
    Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
    2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
    2008 Mac Pro 2.6 Ghz 8 Core, 10GB RAM
    AJA IoXT, Blackmagic Intensity Pro, Blackmagic Mini Monitor
    Adobe Production Premium CC, Avid Media Composer 7, Final Cut Pro Studio 3
    Marco Solorio replied 12 years, 8 months ago 3 Members · 4 Replies
  • John Fishback
    December 9, 2013 at 5:10 pm
    Not v-mount, but this could be attached to a cage or cheese plate.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Marco Solorio
    December 11, 2013 at 3:48 am
    Hey Matt, sorry for the tardy reply. Been crazy busy! The V-lock adapter you saw on my rig was a somewhat generic part that’s actually made for the AJA mini converters:
    https://www.bhphotovideo.com/c/product/699163-REG/Elements_791_0288_AJA_V_Lock_Plate.html/BI/19444/KBID/11604/kw/ELVLPAJA/DFF/d10-v2-t1-xELVLPAJA
    It’s not perfect, but it does work. Other solutions coming soon, so stay tuned.
    The other mount that John linked to also works well for other applications (I have/use both).
    Cheers!
    Marco Solorio | CreativeCow Host | OneRiver Media | ORM Blog | Facebook | Twitter | BMCC Newsletter
  • Matthew Sonnenfeld
    December 23, 2013 at 12:19 am
    Hi Marco,
    Sorry for the delayed response but thank you!
    I actually had purchased the Elements V-Lock kit and was waiting for it to come in. Though unfortunately I had not ordered the AJA version though so I had no way to actually mount it as it was. I did though already have the mounting bracket that John had mentioned so I did use that the mount it to the back of my zwiss plate. All in well, it works well.
    My new, much lighter, rig is based around the Wooden Camera Quick Cage and base, a single Redrock Micro handle, a Zacuto foam shoulder pad for 15mm rods (which is great and cheap), and a Zwiss plate which has the MixPre-D and a Switronix 2 P-Tap v-mount battery plate. Will post a picture next time I have it built!
    Thanks again for your help!
  • Marco Solorio
    December 25, 2013 at 9:34 am
    Right on, dude! Looking forward to seeing some pics!
