Activity › Forums › Panasonic Cameras › Mounting 2 wireless mic receivers, how?
Posted by John Hatcher on July 20, 2005 at 3:11 amDoes anyone know if there’s some sort of saddlebag type mount or anything that will let you mount 2 wireless receivers on the dvx100/a? Any help would be appreciated.
J
Joshua Basche replied 21 years, 2 months ago 4 Members · 4 Replies -
Noah Kadner
July 20, 2005 at 9:34 amI usually just hang them off the tripod or on a belt if it’s run and gun.
Noah
Bob Pennington
July 20, 2005 at 1:55 pmUse the STASIS system with your DVX-100.
https://www.antonbauer.com/stasis.htm
The STASIS provides a shoulder mount for the camera,
The system will allow you to use the full size batteries,
you can then mount the wireless systems using the ABWMK-Kit
(Anton/Bauer Wireless Mic Kit).
https://www.antonbauer.com/wireless.htmIf you add the PowerTap multi kit– this will give 4 outputs
to power your accessories– you could use two to power the
wireless receviers- one to power a light and another to power
an LCD monitor or hard drive.
https://www.antonbauer.com/ultralight_accessories.htm#power
The STASIS has a voltage converter built in to allow you to run
the camera at 7.2 volts.This system has allowed you to power all of your devices
from one battery system– allowing you to standardize and carry
only one battery system. -
John Hatcher
July 20, 2005 at 2:22 pmThanks guys. It’s tricky with this cam I know. I could put an A/B mount on there but then it gets less easy to run and gun and hold the cam in crazy positions. I think I’m probably going to have to do a belt pack type deal with wires hanging out everywhere for now. I don’t know why Jimmybox doesn’t make a 2 receiver holder. UGH!!!! 🙂 Thanks again!
J -
Joshua Basche
July 20, 2005 at 6:27 pmThere is a mount that I believe Sony makes for their wireless mics that allows for a plate with two hotshoe mounts at both ends to attach to the hotshoe mount on the camera making it a two for one. I don’t know the exact name for it but I saw it at the NAB working with the sony recievers. I hope this helps
