[Jason Gillet] “I’m looking into upgrading an older Blackmagic Multibridge system to a better system. They client needs to do HD for Finishing and I’m drawn between the V3HD and the Aja 3x card.”
First off, you’re comparing two completely different things. The Motu is an external box and the Kona 3 is an internal card. If you want an external box, then you should be comparing it to the AJA Io HD.
Second, Motu is an audio company and after looking at their specs and the image of their system, I would stay with AJA. AJA is a broadcast video company and have pretty much been that way since their start. Avid, Autodesk, Media 100, Apple and many other NLE companies use AJA products.
AJA Kona 3 can up / down / cross convert material.
AJA Io HD can up / down / cross convert material.
Big difference is that the Kona 3 can support all the way to 2k production workflows. Io HD is limited to Compressed HD formats, though it can output uncompressed HD.
We run three Kona workstations and also have the Io LA and the Io HD
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow!
Read my Blog!
