Activity Forums Apple Motion Motions stuck on last saved project
  • Motions stuck on last saved project
    Posted by Anwar Smith on June 12, 2013 at 6:23 pm
    This is really frustrating. I am trying to start a new project, but my motions is stuck on the last project and wont let me close them and start a new one. I even uninstalled the program and reopened it and its still stuck on the same project. What can I do to fix this please?
    Chris Lehmann replied 13 years, 3 months ago 3 Members · 2 Replies
  • Simon Modery
    June 13, 2013 at 9:24 am
    This is how to reset FCP:
    https://support.apple.com/kb/TS1846?viewlocale=en_US&locale=en_US
    But I have no idea if that affects Motion in any way or not. Maybe there are similar files in your Library that are motion specific. I am not sitting in front of FCP at the moment so I can’t test it.
    Head of Postproduction
    Motherlode
    http://www.simonmodery.com
  • Chris Lehmann
    June 13, 2013 at 3:20 pm
    I’ll assume you are using Motion 5. First check under Preferences>Project>For New Documents and see if that’s your problem. If you launch the program and it loads a project, try hitting command-W and then command-N, which should close the current project and start a new one.
    If you are having issues with Motion (or any other FCP related program) I’d recommend trashing your preferences using the excellent and free Preference Manager available here: https://www.digitalrebellion.com/prefman/download.html
