Activity › Forums › Apple Motion › Motion4 Reflections
Motion4 Reflections
Posted by Giorgio Poletti on September 7, 2009 at 11:33 amWho can help me!! I can not run reflections. Should we add a generator? Thanks
Giorgio Poletti replied 17 years ago 3 Members · 3 Replies -
Stephen Smith
September 7, 2009 at 12:23 pmReflections work like they would in real life. Add your object. Then create a shape using the rectangle tool. Change the shapes x rotation 90 degrees so the object sites on the shape. Add the reflection to the shape not the object and the the rectangle shape will reflect the object. It work very cool. Hope this helps.
Check out the TV Show Open I did.
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Eyal Shtark
September 7, 2009 at 2:17 pmdo not forget to turn on reflections in the object inspector and in the render drop down menu otherwise it will not show.
Eyal Shtark
Exhibitions and Multi-Media
Team LeaderAdvertising department
ISCAR LTD.
Tel. +972-4-9970371
Fax. +972-4-9970422
Email: eyal@iscar.co.il -
Giorgio Poletti
September 8, 2009 at 12:44 pmReply me thanks x, First answer is just doing it manually, But Io I can not do it just to see how they do in the movie https://www.Pixelcorps.Tv/macbreak_studio047 I also turned around as he says (eyal shtark) but nothing, Looks dead.
