Activity › Forums › Apple Motion › Motion Workflow question
  • Motion Workflow question
    Posted by Paul Nevison on January 9, 2006 at 9:14 pm
    hey there
    sorry if this is a bit basic…but is this the correct workflow for motion (using the roundtrip method)
    make export a reference movie of the section of a sequence that needs work in motion.
    import that ref movie and place on timeline
    select in and out and use ‘send to’ comand from file menu
    work on sequence in motion
    save and changes should be updated in FCP
    the reason I’m asking about this is that i cant seem to just be able to hightlight a section of shots in the sequence and export to motion…it only seems to like single clips. thats why i thought using a ref movie would work.
    thanks
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
    BMD Decklink Extreme
    Paul Nevison replied 20 years, 8 months ago 1 Member · 1 Reply
  • Paul Nevison
    January 9, 2006 at 9:23 pm
    found the handy workflow mini manual – which explained a few things. though it says that I can “send to” any items i highlight in the sequence that doesnt seem to work as i get an operation not allowed message
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
