Activity Forums Apple Motion Motion won’t Save or Export!
  • Motion won’t Save or Export!
    Posted by Iamsoclever on February 13, 2007 at 5:18 am
    Help! I’m running Motion 2.1.2 on a MacBook Pro. I am unable to “Save,” “Save As” or “Export” my projects. No dialogue appears at all. Tried reinstalling, also tried deleting “com.apple.motion.plist” Any ideas? Thx!
    2007-02-13 00:00:14.227 Motion[456] Can’t open input server /Library/InputManagers/Smart Crash Reports.bundle
    2007-02-13 00:00:43.703 Motion[456] *** -[NSNavSegmentSwitchControl cellAtRow:column:]: selector not recognized [self = 0xa55f310]
    2007-02-13 00:00:43.783 Motion[456] *** -[NSNavSegmentSwitchControl cellAtRow:column:]: selector not recognized [self = 0xa55f310]
    Burt Brown replied 19 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Paul Coull
    February 13, 2007 at 8:53 pm
    Try running ‘disk utility’ and doing a ‘repair disk permissions’.
    grafxflow
    grafx that flow!
  • Iamsoclever
    February 13, 2007 at 10:42 pm
    Update: I ran disk utility and repaired permissions – no luck. Next, I created a new user “TestUser” and logged in. Motion DID work under the new user account. That narrows it down a bit, the framework is ok. Unfortunately, I can’t find any uninstall documentation for Motion. If I can just uninstall and reinstall I think it will fix the problem.
  • Paul Coull
    February 13, 2007 at 11:22 pm
    Try this,
    delete
    motion app folder
    library/receipts/motion.pkg (this may differ dependent on version of motion).
    then reinstall.
    grafxflow
    grafx that flow!
  • Paul Coull
    February 13, 2007 at 11:23 pm
    Try this,
    delete
    motion app folder
    then reinstall.
    grafxflow
    grafx that flow!
  • Paul Coull
    Try this,
    delete
    motion app folder
    then reinstall.
    grafxflow
    grafx that flow!
  • Paul Coull
    February 13, 2007 at 11:25 pm
    I Apologies,
    My connection must be causing problems!!!
    OOPS!!
    grafxflow
    grafx that flow!
  • Iamsoclever
    February 14, 2007 at 12:31 am
    Thank you, Grafxflow! After the reinstall it worked just fine. Much appreciated.
  • Burt Brown
    February 14, 2007 at 2:24 am
    Grafxflow:
    Thanks! I’ll give that a try the first chance I get.
    Burt
