Activity Forums Maxon Cinema 4D Motion vector and RSMB problem
  • Anders Hattne
    December 27, 2009 at 12:55 pm
    I think that’s just how RSMB works, cause it can’t tell which pixels are actually moving underneath what..
    I think the way to go would be to mask out the overlaying stucture.. using the object buffer and apply RSMB to a separate layer underneath.
    http://www.ardillamedia.com
  • Luke Harris
    January 14, 2011 at 8:41 am
    Hey mate,
    Just figured this one out. Sometimes the Vectors pass doesn’t render with a correct alpha – check that AE is recognising the alpha, if it isn’t, it’ll just appear as a black background, which stuffs up RSMB.
    Solution:
    Put an Extract effect on the vectors that are precomped – set the black point to 1, making all pure blacks transparent.
    Should all work now!
    Luke
