Motion Troubles
Hi guys and gals…
I have a serious problem with “motions” in Premiere Pro2 on our Aja LHe system.
This machine spent quite a while back at the seller (Promax) recently for a wide variety of service issues, so all of its software and drivers should be absolutely up to date.
He is the latest issue:
“Motions” in Premiere do not function correctly. When attepting to “scale” an image, the image size does not change. The image stays at 100% size, even though the numbers on the scale show it to be of a different or changing size. My senior editor is a veteran Premiere expert and he confirms that I am not doing anything wrong or have any misplaced settings, etc. If I do anything else with OTHER Motion paramenters (such as rotate the image a little), then suddenly scaling works. But obviously that is not a solution.
Man, got to tell ya… I don’t wish to knock Aja, but I’ve just about had it with this machine. It has had one issue after another after another. I just need a suite that is functional, one where I can sit down and immediately work. Not one where I seem to have to jump through endless hoops to do even the simpliest and most mundane of tasks EVERY SINGLE TIME… which is the present situation and has been since we bought it.
If anyone has any advice that will relieve my stress and crankiness it would be most appreciated.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
