Activity Forums Adobe After Effects Motion trail: How to invert a path direction ?
  • Motion trail: How to invert a path direction ?
    Posted by Christophe Charbonnier on November 3, 2008 at 10:02 am
    Hello,
    In order to do a “motion trail” effect, I am applying a vegas effect on a path with just 1 segment and I am animating the rotation attribute. The thing is the motion is “counter-direction”. I want it to turn the other side. I have found a workaround (by inverting the first/end opacity and the rotation evolution), but this does not work when I must stop the motion (by stopping the rotation, and fade-out the length attribute).
    I only want to tell vegas-effect to change the direction of my path.
    I tried to change the first vertex of my path, but this does not work…
    Does somebody know how I can change the direction ???
    Will Sykes replied 15 years, 11 months ago 4 Members · 3 Replies
  • Roland R. kahlenberg
    November 4, 2008 at 2:38 am
    HAve you tried TIme Reversing the keyframes that you currently have? With Vegas, you either rotate clockwise or counter clockwise. You may also want to exchange the start and end opacity values.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Matt Carl
    December 15, 2009 at 7:32 pm
    I was just having the same problem and came up with an answer that worked for me. The time reversing idea would’nt work because that would put the trail of my light streak following the motion path ahead of it’s source. Instead I flipped the solid around (-100 on X) so that the motion path would also travel in the reverse direction.
  • Will Sykes
    September 27, 2010 at 2:48 pm
    You can invert the Vegas stroke by setting the start opacity to 0 and the end opacity to 1.
