Activity Forums Boris FX Motion Tracking?
  • Motion Tracking?
    Posted by Bastian Krüger on January 14, 2012 at 12:55 pm
    (using MC 5.0)
    Does anybody know, how to link an effect (for example a lightning effect) to a motion tracker. Some effects (for example BBC lightning) doensn’t have a possibility of motion tracking inside.
    I found a solution with the BBC Match Move effect. This effect affects to the track below. Therefore, after applying the BBC lightning to the videotrack and applying BBC Match Move to a neutral filler above, I have to change these two tracks. After that, I open the effect pallette and set “MM Foreground” to “First Below”.
    Now, everything is simply good tracked, and it works. BUT: the tracked item (in that example the BCC lighting) is just to see on a black window (frame size).
    Does anybody know, where the error is?
    Thanks…
    Bastian Krüger replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
