Activity Forums Adobe After Effects motion tracking troubleshoot
  • motion tracking troubleshoot
    Posted by Dustin Ward on June 1, 2010 at 5:09 pm
    I did what I thought would be logical. I took my lines that I wanted to stay on the desk and attached them to a Null. I then tracked the map footage and used the Null as the target layer. The track looks great except that the rotation and position of my lines are way off. I can’t figure out what I’m doing wrong. Check the pics. It stays tracked.. just in the wrong spot.
    It should be like this:
    but instead it is like this:
    Tudor “ted” jelescu replied 16 years, 3 months ago 2 Members · 3 Replies
  • Tudor “ted” jelescu
    June 1, 2010 at 5:31 pm
    precomp lines- apply track to precomp. Use Mocha if you have it.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Dustin Ward
    June 1, 2010 at 6:15 pm
    I tried that too, and no, I don’t have Mocha. Would it be an anchor point issue in correlation to the placing of the tracker points, possibly?
    June 1, 2010 at 8:12 pm
    you are tracking position and rotation – correct? If that is true, you may get an offset in position which can be fixed by repositioning using anchor point controls.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
